×Hello! How hide fileds ( in red box) how see on attach screenshot ? I need only fields and button on left side ( my workflow) and activity
Please give me direct link on manual, or right example.
Thanks.
For Source and review tab you will have to disable modules "fisheye issue tab panel " and "crucible issue tab panel" from the system plugin "Fisheye Plugin"
for the above red box i assume its assign to me and assign buttons , for that you need to disable modules " View Issue Ops Bar Assign Link"
and "View Issue Ops Bar Assign To Me Link" from Issue Operations Plugin under system plugins.
System plugins are under administration>>plugins>>Show system plugins
Warning : these are system plugins
Mizan thanks! Why i am expand "JIRA Fisheye Plugin" still waiting and never open settings for disable components?
You should be able to see the modules after you click the "+" sign on the manage plugin modules . there you will have to click the disable button on the right side of the particular module.
No, see this - http://i40.tinypic.com/hsj87b.jpg
And error in IE:
Webpage error details
User Agent: Mozilla/4.0 (compatible; MSIE 7.0; Windows NT 5.1; Trident/4.0; .NET CLR 2.0.50727; InfoPath.3)
Timestamp: Fri, 3 Feb 2012 12:25:46 UTC
Message: 'status-code' is null or not an object
Line: 1012
Char: 2
Code: 0
URI: http://hostname:8010/s/ru_RU-uvbl0n/663/5/1.4.1/_/download/batch/com.atlassian.upm.atlassian-universal-plugin-manager-plugin:plugin-manager/com.atlassian.upm.atlassian-universal-plugin-manager-plugin:plugin-manager.js
i found https://jira.atlassian.com/browse/JRA-24378
where in config file, i can set -Datlassian.dev.mode ?
Hello! Any ideas how to fix? I got error when expand:
Timestamp: Mon, 6 Feb 2012 06:58:04 UTC
Line: 1012
Char: 2
Code: 0
URI: http://host:port/s/ru_RU-uvbl0n/663/5/1.4.1/_/download/batch/com.atlassian.upm.atlassian-universal-plugin-manager-plugin:plugin-manager/com.atlassian.upm.atlassian-universal-plugin-manager-plugin:plugin-manager.js
This may be a browser issue ... try with a latest version of mozilla .
is java script enabled in your browser ? check http://support.mozilla.org/en-US/kb/JavaScript ..
yes, enabled in firefox, enabled in internet explorer. error same in both browser.
may be you should ask another question with a screenshot of error attached. i am sorry i dont know why the error appears.
Ask a new question . Because you have accepted my answer i guess not all will notice it . you can ask a new question here
Sorry, i mark you answer for right - too quick.
Unmark you answer. Path for manage plugin is correct.
you can like it ;)
Good :) ...................
Here is a solution which i just implemented which allows you to decide which buttons you want removed based on Project, Issue Type, and Status. Using the following base, you can see how this can be modified to hopefully fit your needs. I just placed the following code directly into the description of the Component/s field on the field configuration which is assigned to the relevant project/issue type. It uses the alt attribute of the images to control when the buttons of Assign and Assign to Me are removed. This may be able to be expanded for the source and review tabs.
<script type='text/javascript'> AJS.$(document).ready(function() { var workflowState = AJS.$('#status-val img').attr('alt'); var issueType = AJS.$('#type-val img').attr('alt'); var projectName = AJS.$('#heading-avatar img').attr('alt'); if(workflowState == 'New' && issueType == 'Ticket' && projectName == 'IT Support') { var btnAssignToMe = AJS.$("#assign-to-me"); var btnAssign = AJS.$("#assign-issue"); btnAssignToMe.parent().remove(); btnAssign.parent().remove(); } }); </script>
I just tested out some more, and i have modified my script to do exactly as you wanted to do and remove all the buttons except the workflow transitions and also remove the Source and Review tabs:
<script type='text/javascript'> AJS.$(document).ready(function() { var workflowState = AJS.$('#status-val img').attr('alt'); var issueType = AJS.$('#type-val img').attr('alt'); var projectName = AJS.$('#heading-avatar img').attr('alt'); if(workflowState == 'New' && issueType == 'Ticket' && projectName == 'IT Support') { var btnAssignToMe = AJS.$("#assign-to-me"); var btnAssign = AJS.$("#assign-issue"); var sourceTab = AJS.$("#fisheye-issuepanel"); var reviewTab = AJS.$("#crucible-issuepanel"); var editIssue = AJS.$("#edit-issue"); var opsbarOperations = AJS.$("#opsbar-opsbar-operations"); sourceTab.parent().remove(); reviewTab.parent().remove(); editIssue.parent().parent().remove(); opsbarOperations.remove(); } }); </script>
Source and Reviews tabs are only shown to people with the view source control permission, so you can remove everyone from that permission, which will hide them.
On the top bar, you can't really - those all lead to valid options for the users. You can cut the list down by restricting permissions though (e.g. if you disallow comments, it'll disappear from the options)
The tabs are different - you can disable them, but that is global and would remove them completely. If you turn off Fisheye/Crucible integration, they will go away.
