how to activate roadmaps feauture on jira data center ?
sai chinamuthevi
in my company data center we installed advanced roadmaps plugin but i am unable to see in board options how do i activate them ?
2 accepted
Sagar Mahajan
hi @sai chinamuthevi Please confirm if you have installed the plugin and it has all the modules enabled. advanced roadmap is free plugin for Jira data center so not require any license for it to use
If it is installed and enabled you will see the Plan option in the Jira top bar like below
You can configure the further configuration settings by going to the below URL:
https://<jira-base-url>/secure/PortfolioPermissions.jspa
Let me know in case of any issue
sai chinamuthevi
looks like i installed another plugin can you please mention the plugin name and how to activate the modules ?
Sagar Mahajan
The plugin name is same - Advanced Roadmaps
https://marketplace.atlassian.com/apps/1212136/advanced-roadmaps-formerly-portfolio/version-history
You can simply installed using the plugin using the URL from the version history
Sometimes you will not able to find the addons from the find new apps options, so above mention way will help to installed the plugins using the installer link.
Let me know if you face any issues.
Like # people like this
Vickey Palzor Lepcha
May 10, 2021
It does not show on the board. Check the menu bar - you will see a new option called Plan . That is where you create Program and Plans using roadmap plugin.
