hope I will explain myself well
I need to create a custom field called modules and by the module, I choose I will get the components. how can I create that?
and if I cant, I can create it opposite? by the component, i will get my module? TY
Hi Cleno,
There isn't an option to do so in default Jira. However, I believe you can achieve this user an app called ScriptRunner for Jira.
Here you can see more about the app:
https://marketplace.atlassian.com/plugins/com.onresolve.jira.groovy.groovyrunner/cloud/overview
Would recommend you to check the following documentation:
- https://scriptrunner.adaptavist.com/latest/jira/behaviours-overview.html
- https://scriptrunner.adaptavist.com/4.3.4/jira/recipes/workflow/validators/simple-scripted-validators.html
Soane K.
