  • Community
  • Q&A
  • Jira
  • Questions
  • how to define the script of the condition to be met using send a custom email script runner script
mel vega
i'm trying to set up a "send a custom email" script runner post function and I struggle to define the script of the condition to be met.
the condition is based on a checkboxes custom field. The field should be equal to a specific value.
I tried to select "Has string custom field value equal to " in the suggested examples but it does not work and I click Preview, the condition is set as false.
would you have any idea of the right code to write for a checkboxes custom field?
thanks in advance
melissa
JamieA
January 6, 2016
You may find it easier to use the cfValues map which is passed in:
https://scriptrunner.adaptavist.com/latest/jira/recipes/workflow/validators/simple-scripted-validators.html#_validating_a_multi_select_option_is_selected
As Thanos said, with checkboxes it can be multiple. To check for a single specific checkbox being checked, and no others, you'd use:
cfValues['Name of field']*.value == ['An item']
mel vega
thanks a lot to you both. It perfectly works. Just another question : is there a way to reformat the email body and configure a line break for each custom field ? many thanks for your help. it's great
JamieA
January 7, 2016
Hi... I'm not sure what you mean. If using html use <p> markers.. If you paste more of the template that would help us answer.
mel vega
great! i did not know the use of <p> markers ! I'm very very new in coding ! thanks a lot ot's perfect now
Thanos Batagiannis [Adaptavist]
January 6, 2016
Hi Melissa
Below there is a script where you can use in order to get the checkbox values
import java.util.ArrayList
def customField2 = customFieldManager.getCustomFieldObjectByName("checkbox")
ArrayList listOfCheckBoxValues = issue.getCustomFieldValue(customField2) as ArrayList
if (!listOfCheckBoxValues)
	return false
if (listOfCheckBoxValues*.value.contains("option1"))
	return true
else
    return false
A note. By default you can select more than one boxes therefore you always get a list of selected values. In case you want to use radio buttons where by default you can select only one value the script will be slightly different. Please let me know if you need further assistance.
Kind regards
