I want to create a behaviour to set 'Request Participants' based on a selected value in some single select list but I don't know what values does this request-participants-field accept.
I tried something like this:
def market = getFieldById(getFieldChanged()) //behaviour is used when changing this field def reqParticipants = getFieldById("customfield_12211") //this is 'Request participants' field def selectedOption = market.getValue() as String if (selectedOption == "something1") { reqParticipants.setFormValue("user1") }
But it doesn't do anything with user names (users that actually exist in my Jira).
I tried using e-mail addresses instead of user names but with no positive effect as well.
I do tried to use a post function to copy field value from 'watcher field' (that can be populated by this behaviour) to 'request participants' and that worked. But that is only a post function and behaviours seem to be more elegant and universal solution.
If some post function is able to insert a proper value to 'request participants' field then I think that it should be also possible to use behaviours but I don't know what is the proper way to do this.
Any ideas what am I doing wrong?
An easy way to do this is using the Collective Issue View for Service Desk Plugin.
This plugin adds automatically groups of users as Participants.
Thanks a lot, Kristian! That looks exactly like what I was looking for.
You may also find the article at https://confluence.atlassian.com/jirakb/how-to-automatically-add-request-participants-when-creating-an-issue-777026955.html here which shows how you can set users in the request participants field using a Post function which you may be able to convert into a behaviour.
Kristian
Hi Bartek,
Sorry about the link it should of pointed to https://docs.atlassian.com/jira-servicedesk/REST/cloud/#servicedeskapi/request/{issueIdOrKey}/participant-addRequestParticipants
I hope this helps.
Kristian
Hi Bartek,
Service desk uses system fields which cannot be set by the normal JIRA API.
However the latest versions of JIRA Service Desk contain a rest API which will allow you to use a Post Request to set Request participants.
An example of the Add Participants method in the API can be viewed here.
I hope this helps
Kristian
'Request participants' is of type 'Request participants' - it is a locked system custom field that is added by JIRA Service Desk. It works somewhat like multi user picker but not exactly, because you can add also an e-mail address there if a user doesn't have a JIRA account.
It stores people involved in an issue - so it's like a field to store watchers but in a different way. Our 'watcher field' (that is added by installing Watcher Custom Field for JIRA add-on) is easily populated by placing user names like:
watcherField.setFormValue("user1,user2,user3")
What type of field is Request Participants? You can see that in Admin -> Custom Fields. May be a multi user picker?
