×Is it possible to synchronize the issue registered in jira software to jira work management?
I want to display my jira software issues into calendar view of jira work management
@이재화 welcome to the Atlassian community!
Could you explain your use case further, especially on the synchronization part? what type of information did you want to sync between Jira Software and Jira Work Management?
If you want to display Jira Software issues in the Calendar view of the Jira work management project then I am afraid that is not possible.
→yes. that's what i want.
it can't be possible?
thank you for your response
Hi @이재화 ,
This is Dhiren from the Exalate team.
I would recommend you to try out Exalate to achieve this use-case.
It's pretty much possible to sync issues between Jira Software and Jira Work Management and also you would be able to see the issues in the Calendar view.
The tool offers a groovy based scripting interface for limitless customization and flexibility and all fields information(system + custom) can be mapped and synced over Bi-directionally.
Do let me know if you need any more help or have any more questions.
Thanks, Dhiren
Hello @이재화
Welcome to community!
Can you tell us more about your need? Do you want to synchronize existing issues ? Do you want to copy issues from Jira Software to Jira Work Management and synchronize them?
It will be easier to help!
In the meantime, at Elements, we developed an app called Copy & Sync that allows you to copy issues from one project to another and synchronize them (fields, comments, attachments, subtasks, etc.).
If your issues already exist in both projects, you can just synchronize them using a synchronization recipe.
The app is free for 30 days, (and stays free if your instance is under 10 users), so feel free to give it a try.
Let us know!
Regards
Thibaut
Hi @이재화
another thing to consider is that many of the new view and capabilities in JWM are also available for other project types (such as Jira Software projects) through the Atlassian Marketplace. E.g., this app seems like a good fit for a calendar view, and I myself work on an app that many customers use successfully as an alternative or extension to the list view: JXL for Jira.
I understand that apps may mean additional administration effort and costs, but depending on your use cases, this may well be worth it.
Best,
Hannes
