×Hi
I need a filter that will allow me to get the issues that have a Key ending with odd number and another filter with even number.
How could I achieve this in the jql filter?
Thanks in advance
There is nothing in JQL that would allow for this. What is the use case here? Maybe there is some alternative solution. If I understood your used case, I might be able to offer such an alternative.
I guess you could export this to excel and deal with it there.
if you're open to solutions from the Atlassian Marketplace, this would be easy to do using the app that my team and I are working on, JXL for Jira.
JXL is a full-fledged spreadsheet/table view for your issues that allows viewing, inline-editing, sorting, and filtering by all your issue fields, much like you’d do in e.g. Excel or Google Sheets. It also comes with a number of advanced features, including support for (configurable) issue hierarchies, issue grouping by any issue field(s), sum-ups, or conditional formatting - as well as the ability to filter issues via regular expressions.
With regular-expression-based filtering, you can apply pretty much any logic, including the one that you are after:
The regex that I'm using is
[13579]$
which matches any string that ends with an uneven digit.
[02468]$
would be the regex for all even issue keys.
Once you've identified your issues, you can work on them directly in JXL (e.g., bulk edit them via copy/paste), or trigger various operations in Jira.
Best,
Hannes
There is no direct way to filter these issues using JQL filters.
Any of the above two solutions might resolve the issue.
