hi there i know this might be a lil bit tricky but i was requested to create a new custom field that only shows up if a specific selection is made from our Severity field.
i don't want client side solutions such as javascript...does n1 of you know if there is some kind of a condition setup for customfields or any other extended cascading feature that allows this?
sure there is a cascading select list field type but that is not providing the solution i need.
Severity field has values...like sev1 to sev5
when the user selects sev1 or sev2 a new field should be shown wich is a text field where to enter some impacts...
any ideas?
Regards
Ok, I will praise myself again: try JJUPIN, it hides away from you all the JS.
JJUPIN rocks.
I see that JJUPIN did just add new features for show/hide fields!
i will give it a shot. thanks.
any clue if fields can be hidden per conditions such as "only show if cfield_12345 has value in (a,b)" ?
Yes. There are plenty of examples on our site http://confluence.kepler-rominfo.com/display/TR/Recipes
Radu. i just purchased JJUPIN and diggin in the documentation right now.
is there any KB article that comes close to what i need?
http://confluence.kepler-rominfo.com/display/JJUPIN/Live+Fields
http://confluence.kepler-rominfo.com/display/TR/Make+a+custom+field+required+based+on+another+custom+field
http://confluence.kepler-rominfo.com/display/TR/Restricting+resolutions+based+on+issue+type
Email us at "jira-support at kepler-rominfo.com" explaining what you need, and maybe we can push it into the right direction.
This plugin might also serve some needs:
My instinct would be if I could limit it to only one transition, like on "create," that I needed this functionality, that I could hack this together by creating a step in the middle. Then using a plugin with a conditional postfunction, if the severity = X, then it transitions to another status with the screen with the custom field you want. You could create several different transitions to handle different severities.
This is a clunky solution but the only thing I can think of that wouldn't require coding.
The only solutions I've seen for this are
1. A plugin that provides a new field type to do it
2. Javascript
thanks Nic,
can you give me more details for the 1st solution you mentioned please?
There's not a lot to say really - I've worked in a couple of places that wrote plugins to do it. Storage formats were a bit of a pain, but the cleanest one I saw was basically cribbed directly from the code for the cascading-select with some tweaks to the .vm to show/hide the second half of the field as required.
I can't share the code, as it was all internal stuff (and I didn't copy it, as it wasn't mine!)
sure thing Nic.
i guess i stick with some dirty workaround like putting an update field conditon on the customfield during triggering the Resolve transition.
probably the fastest availabe solution
