It's a problem with your network.
https://confluence.atlassian.com/display/JIRA/Surviving+Connection+Closures might help improve Jira's response to the fault, but you probably need to talk to your network engineers and DBAs to find out why the connection is being lost.
Depends on how you've installed it. You should consult the documentation for your version, or the team that maintain the server.
