max limit char in custom field
Wanderson Martins
June 5, 2025
is there a way to determinate the limit of max chars in a custom field of a form? How can I do this?
Olha Yevdokymova_SaaSJet
Hi @Wanderson Martins
If you're looking to set a maximum character limit on a form field in Jira Software native forms doest support this kind of input in forms.
However, if you're open to using an Atlassian Marketplace add-on, Smart Forms for Jira offers exactly what you need.
✅ With Smart Forms, you can:
  • Set a max character limit (and min, too) on almost any form field (e.g. text input, paragraph field)
  • Show custom validation error messages when a user exceeds the limit
  • Use regex validation for advanced control over formatting
  • Apply limits to fields used by internal teams or external users (via the customer portal or public form)
It’s a great way to ensure that responses stay clean, consistent, and within boundaries—especially when collecting things like short descriptions, IDs, or file names.
Aaron Williams
June 5, 2025
Hey @Wanderson Martins
The maximum characters I'm a short field is 255, and paragraph (multi-line) is about 30,000.
Aaron.
Wanderson Martins
June 5, 2025
Hi Aaron, thank you for your prompt response.
Is there a way do customize this size?
Aaron Williams
June 5, 2025
The max limits are pretty hard and fast. You can set character limits in forms that you make though.
Any time you use one of the mentioned fields in a form, the panel on the right allows you to select minimum and maximum character limits for that field.
