×Hi, in our instance we have 2k+ users and 3m+ issuses
I need to get statistic of every text customField on every issue (just table of unique text customField values and it's count)
using groovy script executs 20+minutes
sql just 3 seconds
groovy example
import com.atlassian.jira.bc.issue.search.SearchService
import com.atlassian.jira.jql.parser.JqlQueryParser
import com.atlassian.jira.web.bean.PagerFilter
import groovy.json.JsonOutput
import org.apache.log4j.Logger
def logger = Logger.getLogger("com.acme.CreateSubtask")
def jqlQueryParser = ComponentAccessor.getComponent(JqlQueryParser)
def searchService = ComponentAccessor.getComponent(SearchService)
def user = ComponentAccessor.getJiraAuthenticationContext().getLoggedInUser()
def queryStr = """ "Template Name" is not EMPTY """
def query = jqlQueryParser.parseQuery(queryStr)
def search = searchService.search(user, query, PagerFilter.getUnlimitedFilter())
def statistic = [:]
search.results.each { documentIssue ->
def issue = issueManager.getIssueObject(documentIssue.id)
def customFields = customFieldManager.getCustomFieldObjectsByName("Template Name")
def customField = customFields.first()
def fieldValue = issue.getCustomFieldValue(customField)
if (fieldValue) {
statistic[fieldValue] = (statistic[fieldValue] as Integer)?.plus(1) ?: 1
return JsonOutput.toJson(statistic)
sql example
SELECT
cfv.stringvalue AS "Template Name",
COUNT(*) AS Count
FROM
jiraissue AS ji
INNER JOIN
customfieldvalue AS cfv
ON
ji.id = cfv.issue
INNER JOIN
project AS p
ON
ji.project = p.id
WHERE
cfv.customfield = (SELECT id FROM customfield WHERE cfname = 'Template Name') AND
cfv.stringvalue IS NOT NULL
GROUP BY
cfv.stringvalue
ORDER BY
Count DESC;
I need to execute sql in jira cloud somehow cause 20 minutes is actually bad comparing to sql, what optimization technics could I use or just how to execute sql?
Hi @Viktor Fedun with the cloud, you won't have SQL access. It was suggested in this article that you could use the API to get access: Pulling Data from system
If there are performance issues, I would suggest opening a ticket with support.
Hope that helps.
