I have post function in my workflow where i'm setting date time field to %%CURRENT_DATETIME%%
However it is setting original value and new value in "All" tab as same i.e. new value
This field is on screen which opens on transition of an issue.
I was doing one mistake. I was updating that field after transition. It shoud have been before transition happens.
I'm sorry, what's the problem here? You set a value in the field using a post-function, and it updates the field and the issue history. What's wrong with that?
it is forgetting orginal value, it is setting orginal and new value to new value
Also I noticed, it does not update with current value.
e.g. I updated field at 4:00 PM 1st time
2nd time at 4:05, it shows 4:00 PM as time
3rd time at 4:10, it shows 4:05 as time
No, I still don't understand. You are running a function to set a value, and then complaining that the value is changed as it should be?
This is not making any sense. You're telling me fields that you are changing are changing but not changing at the same time
Please, step back, explain EXACTLY what you are doing, and EXACTLY what you are seeing. Don't guess at what else might be useful or other symptoms, just explain the absolute basics of the problem.
