×When updating issue type on issue then moving to another project I get the below message and although I've removed Creator Field from issue type screens, I continue to get the below.
The screens aren't what control if the value is retained it's the field configuration. If an issue had a value set when a field existed on a screen and the screen is removed the value is still present in the issue's metadata it simply isn't visible to users.
However, if you "hide" a field in the field configuration it won't retain values for that field anymore.
I think that's what you are seeing in this message.
I hope that helps!
-Jimmy
Thanks so much Jimmy. I removed Creator from field configuration and that resolved issue!
