Tempo and WEB Power BI
Vladislav Taran
November 28, 2017
Is there any way to use tempo in web Power Bi? So far, I was able to use JIRA only. Do I need to add separate data source for tempo (which one if so)? Here Tempo with Power BI it was mentioned that another api should be used. I'm exactly interested in the solution for WEB version of Power BI.
Thanks in advance,
Vlad
Sandstorm Media GmbH
May 3, 2018
Hey @Vladislav Taran,
as mentioned in the other post, you could use another add-on to export those data. If you need a complete solution to monitor and control your JIRA and Tempo time data, have a look at Exply for JIRA
sunny regards
Fabian
