Issue with connecting OpsGenie with another company's Jira
Marko Madaras
February 7, 2024
Hello all, I am experiencing issue with connecting our OpsGenie with client's Jira. In our OpsGenie, under Team dashboard > Integrations I go to add client's project to which I have access, but I cannot see the project in the drop-down list. I have checked both Jira Software and Jira Service Management, but the project cannot be found. Any help would be greatly appreciated !
Best regards,
Marko
Alan Violada
February 8, 2024
Hey Marko, Alan from the Opsgenie Support team here.
When creating the integration in Opsgenie, are you selecting the "Cloud" option in the "Integration variant" dropdown?
If so, that will only work if both the Jira and Opsgenie products are under the same Atlassian Cloud site. If you need to set this up with the products being on separate sites, I would recommend using the Legacy Webhook-based integrations:
Integrate Opsgenie with Jira Service Management
If you face any issues while setting that up, I would suggest creating a support ticket at Atlassian Support so we can provide more detailed assistance.
Alan
