OpsGenie Alert is not triggered for a P1 System incident
Wojtek Szczerbinski November 22, 2023
Hi Guys,
I have a problem when trying to trigger an alert for a new team in OpsGenie.
Whenever we have a ticket that meets a P1 criteria it triggers an alert for a designated team. We trigger it based on a Component.
For some reason, it doesn't work for a new team for which I created a new component - DevOps.
We use OpsGenie to trigger an alert whenever the ticket meets the following criteria:
  1. Component matches - DevOps
  2. Issue type equals - [System] Incident
  3. Priority Matches - P1 Critical
I created this set up based on another team that we already created in OpsGenie and for the other team it works flawlessly.
Is there a way for me to find an audit of why it wasn't triggered? Something like the one we have for failed automations?
I don't even see the alert in the OpsGenie.
Let me know if I need to provide anything more related to the configuration of this.
Wojtek
Joseph Kwan December 5, 2023
Hi @Wojtek Szczerbinski , I'm assuming that you are setting up an integration. You might want to check the condition that you've set up for Priority. I think the operator should be 'equals' instead of 'matches'.
I've had similar issues with integration not being triggered when an alert doesn't have a responder team (which owns the integration).
Wojtek Szczerbinski November 30, 2023
Feel free to close this thread. Atlassian Support is checking the OpsGenie configuration inside of our organization.
Sergey Rostovskiy
November 22, 2023
may be do you have already opened alert with same title in opsgenie. Try to close it and resend alert
Wojtek Szczerbinski November 23, 2023
Thanks for the suggestion @Sergey Rostovskiy but I checked and that's not the case here. Any other suggestions?
