×Hi,
When creating an alert in opsgenie with a Grafana integration that must meet the matching criteria of two tags, the alert is not generated for me. If I just leave a label, if it is created. How can I manage more than one tag since I need it to create the alert with different priority types?
Thanks in advance.
I understand that you would like to set a custom priority for Grafana alerts.
Could you please confirm the value that you have added to the priority field in Grafana integration? You could check this from Grafana integration --> Advanced,
Could you check if the variable priority is added there and test it once again?
Best,
Rafa
