With Opsgenie's Incoming Call routing system, is the number provided reachable globally? Can someone from Saudi Arabia call the US-based Opsgenie Incoming Call number?
Hi Mark,
Yes, the number assigned within the Opsgenie incoming call integration should be able to be reached Globally. You should not have a problem calling the U.S assigned number from Saudi Arabia unless there is some sort of restriction from the local carrier.
Thanks so much for reaching out to the community!
Is this answer still applicable?
I have a chat ongoing with live support for the provisioning of a Dutch number, your representative claims that it is fine as he asked a colleague from the NL to test it, but I can't reach that number (using a Belgian mobile).
You say I should ask support from my operator?
Thanks!
