Settings->Advance settings->Automatically refresh cannot be removed
Luc Roy
June 17, 2022
Because of higher security measures at our company, my computer is locked after bad passwords are entered.
1- I cannot figure out how to remove the bad password.  removing the password file in sourcetree and removing the credential from windows does not seem to work.
sourcetree seems to trying to repeatedly enter the password every 10 seconds in cycles of 5 to 10 minutes.
2- I found a menu item that should disable this feature "Settings->Advance settings->Automatically refresh" but each time I remove the check mark, it comes back.
Shivam Naik
June 21, 2022
Hi @Luc Roy ,
Just wanted to confirm since this is the Statuspage Product Community section, are you having issues logging into Statuspage, or is this regarding another login portal? The second step you mentioned does not sound like something within the Product.
Please let us know!
Luc Roy
June 21, 2022
This is within the sourcetree product.
Shivam Naik
June 21, 2022
Hi @Luc Roy ,
I would recommend creating a Support request here https://support.atlassian.com/sourcetree/, that will get you direct assistance with the product.
