Automation: Post Trello card title in Slack-Channel
Daniel Sobolewski
November 16, 2022
Hi!
I want to create an automation-rule doing the following:
When i comment "#fertig" in a trello-card, post the title of the trello-card in a slack-channel.
Is that possible? I only see the possibility to type in a message for slack. In this case, the message would be different in every action...
Regards!
Daniel!
XLR8 Work
November 16, 2022
I don't use slack yet but if you are wanting something dynamic you probably need to be using Trello variables in your message.
https://support.atlassian.com/trello/docs/butler-variables/
To call the card title you would use the {cardname} variable
Hope this helps
Daniel Sobolewski
November 17, 2022
Works out perfectly! Thank you very much.
Like XLR8 Work likes this
