Made a simple automation to send notifications to Slack when task is overdue. But it doesn't work.
Automation log: "An error occurred while trying to post the message: Invalid token
Slack-Trello integration works (I can send message or create card from message).
Revoked and renewed Slack token. Linked it again.
I also revoked Butler token. It didn't appear again.
Solution:
revoke all app keys in trello settings (Butler and Slack)
revoke Trello and Butler from Slack
Unlink Trello from Slack
Trello: Automations -- View Apps -- Disconnect Slack Workspace
Check Trello settings for new app keys -- revoke if exists
Connect Slack again
It was not obvious
