Is there a way for Jira to recognise Trello's markdown?
Aline (they/them)
May 5, 2021
We are using the Jira power-up and we love using Trello markdown as it is simple enough to remember. But Jira does not render the markdown that comes from Trello!
Is there any way to make it work?
Cheers, Aline
Lam
May 13, 2021
Hi @Aline (they/them) Thanks for reaching out to the community! Depending on what version of Jira you're using, there may be differing markdown syntax so it might come out looking different. Unfortunately the only way to resolve this at the moment is by manually formatting your Jira content afterwards.
