"Rules" Help (Automation)
abc123411
April 19, 2021
Hello Helpful people! I'm so glad community help forums exist! :)
I'm trying to use automations to make my life easier. I hate actually archiving cards and I created a "Done" section for any I finished, but after a month of it being in that list I'd like to actually archive it. It doesn't seems like there's a timer function (or one that I've found) Anyone know a trick for this? or some way I can have a card deleted after a month of being moved to a list?
Any help is appreciated! :)
Hannah Humbert - Simpla Workflows
@abc123411 I think this would achieve it for you! Have a look around in the "Calendar" section of Butler.Screenshot 2021-04-20 155026.png
abc123411
June 13, 2021
Honestly this is the best solution. thanks!
<3
You're welcome :)
