Assistance Required for Creating a JIRA Automation to Set Issue Summary
Leena Pratheepan April 22, 2025
Hello everyone,
I need assistance in creating a JIRA automation that sets the summary of an issue based on specific fields. The automation should format the summary using the following fields:
  • Prüfung (customfield_18208)
  • Referenz (customfield_22506)
  • tech_1 (customfield_12721)
The desired format for the summary is:
{{issue.customfield_18208}} I {{issue.customfield_22506}} - {{issue.customfield_12721}}
Please note the specific formatting requirements:
  • An "I" should be placed between the "Prüfung" and "Referenz" fields.
  • A "-" should be placed between the "Referenz" and "tech_1" fields.
I have attempted to configure the rule using the "Edit Issue" action and the smart values as described above. Unfortunately, the automation is not working as expected.
Problem Description:
The fields "Prüfung," "Referenz," and "tech_1" exist in my JIRA project and are correctly configured.
The rule is not triggering
I am unsure if the smart values are being used correctly or if there is an issue with the rule configuration.
Request:
Please review the automation configuration and the use of smart values.
I need guidance or corrections to ensure the rule functions correctly.
Thank you for your support.
Best regards,
Leena
Thanks for your feedback. I've found the problem. I was incorrectly set as the 'Akteur' trigger for the automation. I've made the necessary adjustments and it's now working as expected.
David Berclaz (Apwide)
Hi @Leena Pratheepan
According to my translation:
Edit Issue
ℹ️ Unknown fields were specified during the edit. These might not be available for the project/issue type. Check your configuration for custom fields. Fields ignored –
Summary (summary)
ℹ️ No fields or field values to edit issues (possibly due to field values not being available in a specific project) are present:
AUFSICHT_SCH-203
Can you send a screenshot of your rule action, where you setup the Summary field? As the Summary is a system field, it should look like this:
David
