I am trying to setup a webhook for Git pipelines and post their status in MTeams chat. My problem happens when I iterate through list of "builds" and try to access parent value.
{{webhookData.project.web_url}} WORKS
{{#webhookData.builds}}
{{webhookData.project.web_url}} DOES NOT WORK
{{/}}Is it a bug? Or am I doing something wrong?
When you note this "does not work", what are you observing? What is in the audit log for the rule?
And when you iterate over the values in a list that way, you do not repeat the top-level: just the child attributes. For example (and I have not tested this as I do not know the response data structure):
{{project.web_url}}
{{/}}You may want to log all of the webhookData to see what the structure actually contains.
Hi @Bill Sheboy ,
The structure is definitely correct. I additionally verified it with the "Log" action.
Your example references an element in list iteration, which should be with the full name as:
{{webhookData.builds.project.web_url}}But I need precisely a property one level upper.
What I was describing was when you use a list iterator with smart values, only the child attributes (smart values) are referenced. Please see this documentation for examples with issue fields: https://support.atlassian.com/cloud-automation/docs/jira-smart-values-lists/#Combined-function-examples
You note the structure is correct, so if the iterator is not working I suggest working with your site admin to submit a ticket to Atlassian support for assistance. Your team can do that if you are are on a paid license of Jira: https://support.atlassian.com/contact/#/
