Automation for Jira in Team Managed project with Issue restriction
Antonio Calì
Premise:
1) type of project: Team Managed
2) Restrictions are applied to issues (for example Administrator and member)
Issue:
the Actor “Automation for Jira” can’t perform rules properly (no action performed), results aren't found in Audit Log section using for example JQL conditions in the rule.
I think the issue is related to Actor's permissions, since without issues restrictions all is working properly.
How can I solve the problem?
Curt Holley
Hi @Antonio Calì
Sounds like you pretty much have solved it. You will either have to:
  • remove the permissions from the issues
  • change the actor to one with the right permissions
  • give the current actor the permissions (though I'm uncertain if this is possible)
Curt Holley
Note: option 3 can't be done.
"This user is a system user, and their privileges cannot be modified."
Antonio Calì
Hi @Curt Holley I appreciate your time, but the assumption in my Use Case obviously can't be changed!
If I use a normal user with administrator privileges I had already verified that it works, but it is not the same. The idea of an automatic action is lost.
I thought that somewhere  I could give the privileges to Automation for jira, but I learn from your answer that unfortunately there is no way.
Curt Holley
I don't get how changing the actor to say...you means "The idea of an automatic action is lost".
If you want to keep the actor not related to a person, say....you. Then create a new service account that you can control and add to the relevant groups etc to empower it to run any such restricted issue type automation rules.
Call it  "Admin automation for Jira" or  "Admin Actor".
Bottomline, it can be done, you just need the right actor.
Like Antonio Calì likes this
