Hey,
I am currently working with some automations. Getting emails can be quite annoying and to keep them on my to do list, i have to keep them in my mailbox or create a jira issue. Is there a way to automatically create an issue when an automation fails?
Would love to have a board where the failed automations are registered as for example:
- type: bug
- summary: automation name
- description: the audit log of the fail
- due date: date of error + something (7 orso)
Hi @Sjoerd Bernards -- Welcome to the Atlassian Community!
There is nothing built-in to automatically create a Jira issue for a failed rule execution.
One workaround would be to use email rules in your email application to raise the visibility of the received email, such as with flagging, urgency, alerting, etc.
Another possible workaround would be:
This will not contain all the information you asked for, but it will contain a link to the audit log.
Please note well: even this workaround will not detect all possible rule problems, at least for these cases, no rule error email will be sent...
Thanks for the help, I wanted to avoid using email, but ill give it a try as it is prob the only option.
It's a year later but I have been looking into this and ran across this workaround:
