Automation: Flagging an issue
Truyen Compton
April 2, 2025
When sprints are updated on an issue, are we able to setup an automation that will flag the issue?
3 votes
Marc - Devoteam
April 3, 2025
HI @Truyen Compton
Welcome to the community.
Create an automation.
Trigger: Field changed, on field Sprint
Edit Issue: from the dropdown, select the field "Flagged" and set the value to "Impediment"
Truyen Compton
April 3, 2025
That's the step I missed was updating the value to "Impediment" THANKS!!!
Marc - Devoteam
April 3, 2025
Hi @Truyen Compton
Please accept my answer as a solution, if my answer helped to solve your request.
This will help other community member trying to solve the same.
Like Truyen Compton likes this
Akhand Pratap Singh
Hello @Truyen Compton ,
Yes, you can use Automation for Jira feature
Trigger: Field value Changed and select field as sprint
Action: Select Edit issue and select the field you want to update to flag the issue
