Automation Rule that Assigns an Issue, then Emails he Assignee
Ernesto Donate April 15, 2022
The Rule I have is  set to Run
  • When an Issue is created
  • Check a JQL Condition
  • Then Assign the Issue in Round Robin format to a person in a Group
  • Then Send Email to the Assignee
However, the email isn't sent, and when look in the Audit Log there is a message:
"There is no value set for the field:
assignee"
Is it possible for a rule to set an assignee and then email the assignee?
Thank You
Mohamed Adel
April 15, 2022
Hi @Ernesto Donate
Please before sending the email step add the following action :
Re-fetch issue data
Regards
Mohamed Adel
Bill Sheboy
April 15, 2022
Hi @Ernesto Donate
Yes, and...to the answer from @Mohamed Adel
When using the Issue Created trigger, sometimes the rule can start before all of the issue's data is available.  Adding a Re-fetch action immediately after your trigger will slow down your rule and try to reload the data before proceeding with any other processing.
Like Darryl Lee likes this
Thank you @Mohamed Adel , and @Bill Sheboy . I will try this. Have a great weekend!
Ernesto
