Hi all,
I have an Automation and I am trying to check on related issues that also meet another criteria (that they are not closed) but I am having trouble with the Matching JQL field.
Does anyone have any ideas what JQL I could use here?
Hi @Syd Heller
The "matching JQL" for that Related Issues condition must be well-formed JQL. That is...
<some_Jira_field> <some_operator> <some_value> ...and so on
{{issue.resolution}} cannot be on the left-hand side of the JQL as that would try to compare a value to another value.
Please try this instead:
resolution IS EMPTY
@Syd Heller Could please elaborate ? What errors are you getting ? Also Resolution is empty is different than Issues not closed .
Nicolas
Sure, apologies, here is the error I get:
Sure, they are not the same. For us, Resolution is empty would be sufficient, or Issue is not "Done" or "Declined" would work too if it's easier.
Thanks for the help!
