Hello community,
I am trying to figure out how to create an automation rule that creates an Epic and Stories (associated to the epic) in Project A (Jira) using a manual trigger in Project B (Jira Service Desk).
Once the Epic and Stories have been created, I want to link (issue link) the Epic created in Project A to the request in Project B.
So far, I was able to create and link the epic from project A to my request in Project B but I am struggling to create the stories and associate them with the epic.
Thanks for your help!
Gabriel
Hi @Gabriel Viger - I think the easiest way (possibly the only way?) to this would be to use two rules.
Rule 1 - Your manual trigger rule, where the epic in Project A is created and linked to the request in Project B.
Rule 2 - Triggered when an epic is created; creates stories in project A, and links them to the trigger epic.
Hope that helps!
Hi Kevin,
I was actually able to produce a global rule that answered my needs.
Creating the a global rule targeting 2 projets is the only way it can work.
Thanks for the follow-up!
Gabriel
