Automation to Track WIP
Fred
I'd like to count issues:
WHEN an issue transitions to In Progress
AND there are more than 8 issues already In Progress (count these)
THEN send a message
Should I be using this?
{{lookupIssues.size}} greater than 8
Bill Sheboy
April 7, 2021
Hi @Fred
I cannot tell if you are on Server/Data Center or Cloud version, so...
Lookup Issues will work for Cloud version, so your check on the size can work with the JQL you supply.
For Server/Data Center, you may want to try a scheduled rule instead so you can check on {{issues.size}}
And regarding WIP measures, we also use automation to track Age of WIP.  Here is a how-to for that rule.
Best regards,
Bill Sheboy
April 7, 2021
Gotcha; Please try a rule like this to send a message when issues are moved into progress.
  • Trigger: issue transitioned, selecting all of your in-progress status values for To Status
  • Action: LookupIssues on JQL, inserting your project name
project = myProject AND statusCategory = "In Progress"
  • Advanced Compare Condition: {{lookupIssues.size|0} is greater than 7
  • Action: send an email... or post a slack message... or...
Please note: by design JQL lookups inside of rules exclude the trigger issue, so I lowered the condition value to 7 for the condition test.
Like Utah Nickel likes this
Fred
Amazing! This works perfectly, and it gives me a whole new avenue to explore.
Like Bill Sheboy likes this
Bill Sheboy
April 7, 2021
Fred, I am glad to hear that helped.
Here is a related suggestion for improving WIP management that you may want to watch: https://jira.atlassian.com/browse/JSWCLOUD-21297
Fred
It's Jira Software, Cloud version.
I'm looking for a way to 'count' issues and not expressly finding it.
Deleted user July 12, 2022
This....I've tried using the Jira javascript charts gadget, but the "Count of Issues" will not support a daily count between 2 different dates.
What it only ends up showing is how many things TRANSITION into a particular state (per the query), but it doesn't keep a count like a Cumulative Flow Diagram might demonstrate.
It's almost as if this "Daily WIP count" should be obvious, especially for those using Kanban or strictly flow-oriented process workflow.
