Hello, I've search high and low on some documentation on creating a Bitbucket branch from a Resolution type in Jira (In Progress, Done, etc...).
Hi @Nathaniel Epps ,
Unlike with Confluence, there is no direct integration of Jira automation with bitbucket to achieve this. However you can use this REST API in a webhook action to achieve the same.
Hope that helps!
~ Hariharan
