Looking to make an automation triggered if the issue is new OR if the issue is moved. Need to know how to combine two EITHER/OR triggers. When building, I can only seem to replace the first trigger with the second one or to stack triggers that must all be true. Is there a way to make my two triggers with an OR functionality?
Hi @Kel Hill
Have you tried the Multiple Issue Events trigger:
https://support.atlassian.com/jira-software-cloud/docs/automation-triggers/#Automationtriggers-Multipleissueevents
