Confluence Create a folders and sub-folders using automation
Yaniv December 1, 2024
How can I set an automation to create a folder and sub-folders?
The preferred way is by a condition of a label added to the main folder but manually triggered is also ok.
This is the folders structure I need:
  1. Main_Folder
    • Sub-Folder 1
    • Sub Folder 2
    • Sub Folder 3
Thanks (-:
Manon Soubies-Camy
Hi @Yaniv,
As far as I know, you cannot label a folder. If you’re referring to a parent page instead of a folder, here’s a rule you could use:
I suggest adding {{triggerPage.title}} as a prefix to the folder name, because a space can’t contain duplicate folder names. Without this step, you might get a “This folder already exists” error.
Hope this helps!
- Manon
