Copy two cascading field values from Parent to Sub-task
Sarath March 8, 2021
Hello I have two cascading fields, where I want to copy the value from parent to sub-task. I'm using advanced edit option to update using JSON function. I have used following lines,
"update": {
"customfield_1234": [
"set": {
"value": "{{triggerIssue.fields.customfield_1234.value}}",
"child": {
"value": "{{triggerIssue.fields.customfield_1234.child.value}}"
"update": {
"customfield_5678": [
"set": {
"value": "{{triggerIssue.fields.customfield_5678.value}}",
"child": {
"value": "{{triggerIssue.fields.customfield_5678.child.value}}"
but I was getting error, "json" cannot be parsed.
Any appreciate will be helpful. Thanks.
2 accepted
Bill Sheboy
March 8, 2021
Hi @Sarath
In your sample JSON, the curly brackets are not all matched:
  • there is a missing close } for the first update
  • there is a missing close } for the overall expression
Please add those and see what happens.  Thanks!
Best regards,
Thank you @Bill Sheboy, identified that "}" are not updated correctly and using only 1 update field worked as well.
Darryl Lee
JSON validators like https://jsonlint.com/ or a JSON-aware text editor like Vim have proven invaluable to me for checking my JSON.
Like # people like this
Sarath March 9, 2021
Thanks for the recommendation @Darryl Lee I'll check them out.
Gareth Cantrell
March 8, 2021
Hi @Sarath , this is because you have duplicated the "update" field in the JSON. Each custom field should be a separate key inside the "update" field as in the below example:
"update": {
"customfield_1234": [ ... ],
"customfield_5678": [ ... ]
@Gareth Cantrell - thank you Gareth. Using only one update function worked along with correcting number of curly brackets.
Darryl Lee
I was curious what would happen if you do have two updates in the same JSON (properly formatted). Turns out that Automation Rules does complain that the JSON is invalid, but it only acts on the second one, presumably because it reads/loads the JSON in order and the first update gets overwritten before executing.
So with this block, only the Description got updated:
"update":{
"summary":[
"set":"This is a new Summary to replace."
"update":{
"description":[
"set":"This is a new Description to replace."
(I know my indenting is not-good. I blame the Community text editor stripping the spaces. :-/)
Gareth Cantrell
March 9, 2021
@Darryl Lee a JSON object is represented as a hash table internally, so while it is not an error to have the same key appear multiple times, the properties of a hash table mean that the value of the earlier key will be overwritten if the same key is encountered later during the parsing of the JSON.
Like Darryl Lee likes this
Raul Pelaez _TecnoFor - Marketplace Partner_
An example with Automation Cloud to copy two cascade fields from parent to sub-tasks
"fields": {
"customfield_10071": {"value":"{{triggerIssue.parent.customfield_10071.value}}", "child":{"value":  "{{triggerIssue.parent.customfield_10071.child.value}}"}},
"customfield_10069":  {"value":"{{triggerIssue.parent.customfield_10069.value}}", "child":{"value":  "{{triggerIssue.parent.customfield_10069.child.value}}"}}
Jonathan
I tried this (DataCenter), but I'm getting an error:
(operation must be string (customfield_12420))
