Hi All,
I am stuck on a rule - please could someone help or offer any advice?
I want to create a rule that looks like this:
Using Zephyr Cloud plugin.
Any ideas would be much appreciated as always from this knowledgable community.
Thank you in advance
Unfortunately this is not possible - Zephyr is not accessible in Jira Automation.
Welcome to the community.
Which version of zephyr do you have, the latests one as seen on the marketplace, with issue types in Jira?
then this could be done, but this is bad practice a test is valid for the time it serves its purpose a test execution is transitioned based on its outcome
Hi Mark, Krzysztof,
Zephyr integrates with Jira and uses Issue types which can be used in automation, but everything inside the Zephyr app (test cases, executions, etc.) isn't accessible in automation.
@Krzysztof DrzyzgaSmartbear has a Zephyr Community - I'm very active there with a few others - which you can find here: Zephyr Scale Community
