Find tickets with same summary from same reporter
Volker Kiehn July 15, 2022
Hello together,
I'm testing an automation to find out duplicated sytem messages send via mail. I tried these suggestion
https://community.atlassian.com/t5/Automation-questions/Look-for-same-Issue-Summary/qaq-p/1512490
The system does not recognize the ticket id so we can not add this to the mail subscrition.
The automation is running well, if there are no special characters in mail subject. If there is for example a colon, it fails
Following part of the jql fails: AND summary ~ "{{issue.summary}}"
I tested also manually with jql or advanced search funktion
summary ~ "WG*"     -> is running well
summary ~ "WG:*"    -> doesn't find anything
We need to compare strings like this
WG: [Failed] XYZ - My Veeam Report (Last 24 Hrs) - SRVNAME
Volker Kiehn July 22, 2022
Hi @Bill Sheboy
I got a solution from the support.
Using
summary ~ "\" {{ issue.summary }} \""
instead of
summary ~ "
issue.summary"
makes me able to use the example described here
best regard
Volker
Bill Sheboy
July 16, 2022
Hi @Volker Kiehn
JQL is not an SQL, and so you cannot search for those exact matches, particularly with non-alphanumeric characters, with out-of-the-box Jira features.
Without knowing more about your use case and what the automation rule is intended to do, one suggestion would be using JQL to get close matches (e.g. with a scheduled trigger or branch on JQL), and then use advanced compare conditions in the rule for further testing.  The text functions using regular expressions should be able to detect the rest.
Volker Kiehn July 19, 2022
Hi @Bill Sheboy
I opened a support case for this issue. Unfortunately I don't have influence on the mail subscriptions send to our jira.
I have to compare via variable. so i have to compare the hole title.  I'm using this JQL
reporter in (issue.reporter) AND summary ~ "issue.summary" AND created != "issue.created.jqlDateTime" AND status not in (Closed , resolved)
As I described it's running well without special characters.
best regards
Volker
Like Bill Sheboy likes this
