How do I configure my Jira project to use a unique workflow scheme for each component defined?
Jason Bernas August 10, 2025
For example component A would use Workflow A.
Component B would use Workflow B.
Jeroen Poismans
Hi and welcome to the community!
Workflows can differ in a different project and for another issuetype. Those are basically the 2 options.
If you want slightly different approach within a workflow, based on components, you can try to achieve this with conditions (hiding for component A and showing fro component B).
If that is not enough, really consider creating a separate project / issue type for both, because then clearly they require a different process.
Jeroen
Jason Bernas August 11, 2025
Jeroen – Thank you for describing my options. I have not considered taking different workflow transitions based on components.
My use case requires one Jira project. Can you point me to instructions or examples of how to introduce different workflow transitions based on components?
ahsanriaz
August 11, 2025
In Jira, workflows are attached to issue types, not components. You can still achieve “component-specific” behavior in two ways:
Option 1: Single workflow with branched paths (same issue type)
Build one workflow that contains separate paths for each component (e.g., A-path, B-path).
Add conditions/validators on transitions so only issues with the matching Component can use that path.
(Optional) Use automation on issue create to set the initial status based on Component.
Option 2: Multiple issue types mapped to different workflows
Create separate issue types per component (e.g., “Bug – Component A”, “Bug – Component B”).
Map each issue type to its own workflow in the Workflow Scheme.
Use Automation on issue create to detect the Component and change the issue type accordingly.
Recommendation:
If you want a pure native approach and clear separation, use Option 2. If you prefer to keep a single issue type and don’t mind a more complex workflow (or using apps like ScriptRunner/JMWE for conditions), use Option 1.
Thank you for articulating my options. I intended to follow Option 2. However, in Automation I'm having trouble to Add an action.
My Automation rule is:
When: Value changes for 'Components'
Components contains any of "FW Integration"
Then: Add an action
I don't know how change the issue type on the last step.
ahsanriaz
August 11, 2025
Jason Bernas August 12, 2025
Thank you for your snapshot. It was helpful. I followed it and enabled the automation rule. However, it did not take affect.
My snapshot above indicates it is enabled.
I don't know how to confirm the automation rule is taking any action or it cannot overwrite these defined workflow schemes.
