How to utilize OR condition within multiple components
Kunal Kumar March 30, 2023
I have a reqmt wherein I need to check multiple fields if they are EMPTY upon new issue creation and if yes,  then send an email to the reporter. How do I add multiple conditions in the same rule such that they use the OR condition for checking the fields ( email should be sent even if any one of the field amongst the multiple fields is EMPTY) . Currently the rule only seems to take AND conditions and only If all the specified fields are EMPTY , sends and email.
Bill Sheboy
March 30, 2023
Hi @Kunal Kumar -- Welcome to the Atlassian Community!
First thing, using automation rules requires both learning and experimentation.  I encourage doing both to see what can help to solve your needs, and when you get stuck to then post a question to the community.
To get you started on creating your rule, please review this documentation and examples:
For your specific question, you may try an advanced compare condition, and use the conditional logic to build an expression for this test, using the or() function: https://support.atlassian.com/cloud-automation/docs/jira-smart-values-conditional-logic/#or
Please note: The or() function only takes two parameters.  If you need to test more things you need to chain them together, such as with:
{{#if(or(A,or(B,C)))}} At least one thing was true {{/}}
Rahul Gupta
October 17, 2024
Hdd
Gd
