I want to create an automation based on Issue type.
Adem Kaya September 7, 2023
Greetings atlassian community.
I want to create an automation based on Issue type. For example, when a new issue is opened, the description field will automatically display the articles that I have determined. I can do this, but I want different messages to appear depending on the task issue type. If it is a bug record, the description should be different for those with this issue type. If it is a development task, different articles should appear. Currently, texts appear only when the issue is created, I cannot print differently in a specific task.
4 votes
Holger Rösch
Hi Adem,
you can do this using a IF/THEN Condition after the trigger:
there you can check for the specific issue type
Hope this helps.
Best,
Holger
Adem Kaya September 8, 2023
This answer worked for me. Thanks
Sebastian Krzewiński
Hi @Adem Kaya
In trigger (WHEN) you cannot add condition). After WHEN please add branch and condition in each branch where you will limit to issue types that you need.
Seba
