×Hi guys,
I need to link/unlink issues via an Incoming webhook trigger.
For adding issue links, I currently use 'Edit issues' action with the following additional fields:
"update": {
"issuelinks": [
"add": {
"type": {
"id": "{{webhookData.issuelinktype}}"
"outwardIssue": {
"key": "{{webhookData.link}}"
However, 'remove' is not supported.
I checked the unlink issues action, but I cannot use smart values for the issuelinktype (I have to determine this!) - otherwise I would have to provide a webhook for each possible issuelinktype.
Any other possibilities I missed?
Best, J.
Have you already resolved this?
If not, the only way I found to remove things from list fields (e.g. Component, Labels, Version, Links) is to treat them like strings, and...
Best regards,
