I have created an Automation, where the issue is cloned multiple projects,I would like to restrict issue cloning in the origin project because it will be two similar issue in the origin or Trigger project.
Please share screenshots of the details of your rule as it exists right now.
Kel
To restrict issue cloning in the origin project using Jira Automation, you can add a Issue fields condition. Here’s how you can manage this;
Best
Murat Seven
Hello Murat,
Thanks for the reply
I the automation trigger is issue created it can be from any project but it should skip that project which is triggered,current problem with the automation is that it is also cloning the issue in the project that the issue originally comes from
