What version of Jira are you using: Jira Cloud, Server, or Data Center?
For Jira Cloud, I confirmed this works:
If you are willing to try a third party-app, our Deep Clone for Jira can clone projects and issues, including their attachments. It's as easy as checking one box in the Deep Clone configuration.
Hello @Anth.Burnikell
If you're seeking for an easy way to clone a ticket to a different project with the attachments, you can try our app Elements Copy & Sync that allows you to clone and sync a full hierarchy of issues with all their content (summary, description, custom fields, comments, attachments, etc).
The app is compatible with Automation, you can check our guide here.
You can try the app for free during 30 days (and it stays free under 10 users).
Clara
@Anth.Burnikell you might take a look at this thread: https://community.atlassian.com/t5/Marketplace-Apps-Integrations/How-do-I-copy-attachments-when-cloning-an-issue/qaq-p/400339
HTH
Nicolas
