Jira Automation: Edit issue from webhook
Jesper Skytte
March 30, 2025
Hi! :)
In Jira Automation, the webhook trigger can either get an issue from the request, find it based on JQL or get no issue at all.
I have a scenario, where an issue key could be sent along in the webhook or not.
I want to take the issue from the webhook (if provided) and do something on it, but if no issue key is provided, do something else.
My problem is that the automation fails with "No issues from the webhook" when no issue key is sent.
Do I really have to create to separate automations for this?
6 votes
Bill Sheboy
March 30, 2025
Hi @Jesper Skytte -- Welcome to the Atlassian Community!
Short answer: When you want to provide the work items (previously called "issues") directly or send a key, then "yes": two rules would be needed.
However...as "providing the work items" seems to send the keys as a list and then the trigger processing gets them to iterate, a workaround would be:
  • select the "no work items from the webhook" option
  • send the list of work item keys as data in the request
  • use a JQL branch to access them
One limitation with this approach is any actions on the work items will need to happen inside of the branch (or by calling a different rule using an additional Incoming Webhook triggered rule).
