Jira Automation sending POST request to python script
Sureshkumar S
September 22, 2023
When I send a post request to python using Jira automation "SEND Web Request: POST" I got the below error.
Server: squid
Mime-Version: 1.0
Date: Fri, 22 Sep 2023 20:06:16 GMT
Content-Type: text/html;charset=utf-8
Content-Length: 3114
X-Squid-Error: ERR_ACCESS_DENIED 0
Vary: Accept-Language
Content-Language: en
X-Cache: MISS from ip-10-125-126-94.net.atlassian.com
Via: 1.1 ip-10-125-126-94.net.atlassian.com (squid)
Connection: keep-alive
Marcus Jones
The solution is to add the port 5000 in /etc/squid/squid.conf :
acl SSL_ports port 443 563 5000
However, adding to the SSL_Port section is OK, but it means everyone gets access to it.
You can restrict even further, so that only a single IP address, or multiple IP addresses can only access this port! Just in case you don't want the whole network to have access.
Sureshkumar S
September 25, 2023
Sorry, Marcus. This is my 1st time developing an API program. Please elaborate on how we need to configure /etc/squid/squid.conf. My code is my local machine (Windows), and I exposed my local host online using the Flask library. I want to send the post request to my local dev env.
