Not empty string response after executing webhook
Andrii Volynets
May 28, 2025
I am creating the Jira ticket using a webhook like
curl -X POST -H 'Content-type: application/json' -H 'X-Automation-Webhook-Token: ****************************************' \ https://api-private.atlassian.com/automation/webhooks/jira/a/*******
The automation successfully creates the Jira ticket with the Create work item action.
How can I retrieve the Jira ID or link to the created ticket using the curl response?
Is there any way to log it back to a terminal or use an additional webhook to find the issue?
Marc - Devoteam
May 28, 2025
HI @Andrii Volynets
Why are you triggering an automation rule via a webhook to create a ticket?
Why not just create the issue via the API endpoint to create a ticket? https://developer.atlassian.com/cloud/jira/platform/rest/v3/api-group-issues/#api-rest-api-3-issue-post
Andrii Volynets
May 30, 2025
Thanks for the hint. I will take a look. I used the webhook because it doesn't require the Jira API token.
