Processing misses during "Issues provided by running the following JQL search"
Martin Cleaver
April 26, 2021
I have an upstream system that calls an Incoming Webhook where the JQL looks for a match of the incoming data with a pre-existing issue in Jira. It works great if the record exists.
But I want take alternative set of actions if the webhook doesn't match.
What's the best way to handle this?
Andreas Knecht
April 26, 2021
Hi @Martin Cleaver ,
We don't support this yet, but are tracking this request at https://codebarrel.atlassian.net/browse/AUT-358
There isn't really any workaround unfortunately.
Andreas
Bill Sheboy
April 26, 2021
Hi @Martin Cleaver
Would you please provide more details/context to help the community give you ideas?  Perhaps post an image of your automation rule and the JQL that you want to have "no results" take action.  Thanks!
Best regards,
