我想将第一个网络请求上{{webhookResponse.body}}智能值引用到下一个网络请求他获取的为空值,我的第一个网络请求获取的内容就行一串文本而不是json格式的数据
通过curl command输出结果
第一个网络请求请求
引用第一次网络请求请求的{{webhookResponse.body}}但是获取的是空字符串
Hi @Ops Linux,
This looks like it should work. Can I suggest you open a support ticket so that we can investigate further?
Simeon.
您好,@Simmo
I have solved the above problems. I changed my method. I can print {{webhook_response. Body}} in the comment area. Although it has been solved, there are still some problems with the intelligent value reference between the two send web requests. I'm not sure whether it is caused by the bug of JIRA automation itself
What is the issue you're facing, can you provide some examples please?
