Community, I'm interested to learn about the common integration tools that you use to integrate Jira/JSM to external applications. Do you use direct API integrations and custom coding for automation? Do you use any marketplace apps? Any feedback on Workato or other native integration tools would be helpful. Thanks in advance.
HI @Prabhu Palanisamy _Onward_
I work with team Exalate, a bi-directional synchronization solution for different ITSM platforms. As you can imagine my days are spent talking to clients who are looking to integrate Jira with Jira or with other systems. I hardly come across anyone these days who is using a build-it-yourself approach simply because of the resources and maintenance required to keep such an integration going. In fact, we come across several organizations who have tried the DIY approach, and are not looking to switch to an application.
But whether it is a DIY solution or an app, I believe a vast majority would be using APIs under the hood.
Please let me know if you have any specific questions and I would be happy to take this interesting topic forward.
Majid
Generally, I'll do the integrations from Jira, using Scriptrunner, but Zapier and IFTTT are good when it's better to do it from the outside (i.e. the other system is the thing triggering a need to do something inside Jira)
When there are good integration apps though, use them - only look to create your own integrations when there is no app or the ones you find do not cut it. Lean on previous experiences.
Blatant advert: Nowadays, though, I use https://www.adaptavist.com/products/other-apps/stitch-it - it makes integration between piles of Atlassian systems a doddle, supports a few non-Atlassian apps and we're adding modules for more non-Atlassian systems as customers adopt it and we come to understand their needs more.
Hi, @Prabhu Palanisamy _Onward_
In 99% of cases I use REST API. Realization depends from requirements.
Thank you. Have you use any middleware/ESB? Are there any marketplace apps that perform native API integrations?
